Oil Filter Dilema on Kohler Command Engines
Old 06-29-18, 06:18 AM
This is an email I just sent to an ebay seller regarding a pack of 12 oil filters for Briggs, Kohler, Kawasaki etc. Any comments from you folks.
Hi -- I repair power equipment. I have used one of these filters on the last three Lawn Tractors I have serviced. They all had Kohler Command engines. I am very concerned as each engine called for 2 qts of 10w30 oil. I put in the two qts and each engine read very high on the dipstick like there was too much oil in the engine. This was after I started the engines and checked for leaks. I had been using oil filters from Rotary previous and never had this problem. Please respond with you comments.
Old 06-29-18, 02:37 PM
W
Received 16 Votes on 15 Posts
How did you get the old oil out of the engine? Could some of the old oil have remained in the engine?
Old 06-29-18, 05:30 PM
I use a vacuum pump and then check it with a coat hangar to make sure it is empty. The dipstick shows perfectly clean new oil. I am concerned that the oil is not making it into the oil filter.
Old 06-29-18, 07:20 PM
D
Received 36 Votes on 29 Posts
I think its the wrong oil filter & it holds less oil than the old filter. I would think if it was much smaller, you'd notice a size difference which would make my thought invalid. But, I'd size them up & see if there is a difference. When you're dealing with just two quarts, a little over will make a big difference sometimes.
