B&S vanguard 18hp horizontal shaft not running right
Old 07-01-18, 08:06 AM
B
Hello, i have a 18hp vanguard motor model number 350477 that needs to be choked half to full to run correctly. I have cleaned the carburetor, changed the air cleaner, new fuel filter, new plugs, 91 octane gas, new oil and filter. I was going to varify the adjustment on the nikki carb but i dont see an air, idle screw or any other adjustments. It does not smoke. If it is full throttle it will surge and have no power the die. If i have the choke at a quarter it will sound like there is a crackling coming from the carb. Not a back fire. I am fairly familiar with motors but not to good with carbs. Any ideas please share
Old 07-01-18, 09:28 AM
B
Received 50 Votes on 44 Posts
Verify float level and adjust if needed. Also check carb to engine gasket for cracks and replace if in
doubt.
Old 07-01-18, 01:09 PM
cheese's Avatar
Received 23 Votes on 20 Posts
Something is clogged in the carburetor still. I'd take it apart and get some carb cleaner and a set of torch tip cleaners and poke through all jets and passages and blow through them all with the carb cleaner. That usually does the trick.
Old 07-03-18, 03:02 PM
B
Hello, thank you guys for all your help. It is running alot better now. I dont know which specific thing it was because i did them all while i had it apart. Thanks again
Old 07-03-18, 10:55 PM
cheese's Avatar
Great, thanks for the update!
