Troy-Built Xp 2600 PSI pressure washer no water out of outlet
As stated in the title, I'm getting no water out of the outlet with the pressure hose and gun off. I can get water to come out of the unloader valve hole if I remove the unloader but I'm unsure if replacing it would be the right course of action. I think its the unloader since im getting water up to it. Any ideas as to what it could be other than that? I've got no problem replacing it if you guys think that would be problem.
Start from the last place you get water and check at each connection, with the hose disconnected does water flow, then the hose, then the wand then the tip. Have a good one. Geo
