tecumseh knocks on start up
Old 07-16-18, 11:09 AM
5
Lawn boy mower knocks hard on first few revalotions. Runs fine then on . Not loose blade or tin rattle. Have cleaned gas tank put in fresh gas. took off head cleaned carbon out, new plug correct number. new carb, engine 6.5 tecumseh lv195ea does not rattle while running, good power, good compression Im open for ideas thanks
Old 07-16-18, 11:51 AM
V
Received 2 Upvotes on 2 Posts
What is the viscosity of the oil that you're using ?
Old 07-16-18, 01:21 PM
G
Received 23 Upvotes on 22 Posts
Loose blade, check that a washer is not missing letting the blade bolt bottom out, remove the blade and reinstall it. Have a good one. Geo
Old 07-16-18, 07:01 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
I'm with blade not tight enough or engine mounting bolts not tight enough.
Old 07-18-18, 08:23 PM
5
Good idea I will change to heaver oil and see what happens. Blade not lose Thanks
Old 07-24-18, 12:10 PM
5
Good ideas thanks guys put in heaver oil and retighted bolt on blade bolt had bottomed out Thanks for the help
Old 07-24-18, 03:34 PM
G
Success is a wonderful sound. Have a good one. Geo
Old 07-24-18, 06:01 PM
cheese's Avatar
The heavier oil might bite you int he long run, don't go over sae30.
Old 07-30-18, 06:52 AM
5
Used 30 weight now had 10-30 before thanks
