16hp briggs
Old 07-22-18, 01:22 PM
G
16hp briggs
I would like to know how a problem with an internal governor would act if it was going bad on a briggs 16hp motor
Old 07-22-18, 02:37 PM
Received 30 Upvotes on 29 Posts
The carb wouldn't open up under load or, on the other end of things, it may over rev.
Old 07-22-18, 10:50 PM
Received 125 Upvotes on 110 Posts
And they almost never go bad, what's the real issue your having with the motor?
Old 07-23-18, 07:10 AM
G
Received 23 Upvotes on 22 Posts
Post the engine model, type and code so someone can see what engine you are referring to, there are many 16hp Briggs. Have a good one. Geo
Old 07-23-18, 08:59 AM
G
hi model is303777 Type 0411-21 code 91111211 I took this mower in because I was having trouble starting didn't want to turn over.I tried to adjust the lifters and end up bending a push rod. put a new one in and took it in .they told me that i had a bad governor and need a new engine.The engine is vibrating when running doesn't miss almost sounds like an exhaust leak at first.Been running it like that for some time.also the carb is opening under a load Thank Ken
Old 07-23-18, 09:08 AM
G
sent message don't know if I did it right
Old 07-23-18, 02:38 PM
If you bent a pushrod it means you set it too tight and without lash the cam did a job on the rod.
Reset the lifters at .005 clearance with the flywheel 1/4 inch past TDC. ( that means the piston is 1/4 inch down from the top of the cylinder). Then see how it runs.
Old 07-23-18, 02:45 PM
Another thing that shows up here fairly often in a twin coil ignition are the diodes in the kill circuit. When defective it cause a cross firing in the ignition. That can be diagnosed by disconnecting the kill wires from the coils.
Old 07-24-18, 08:03 AM
G
I put new plugs in and it ran terrible also got shocked when I put my hand next to the plug that was running bad.put old plugs back in it ran fine
Old 07-24-18, 09:13 AM
It's running well now and you attribute the problem to the spark plugs?
Old 07-24-18, 02:09 PM
G
No it is still running as before it ran worst with the new plug one cylinder. Do I disconnected both ground wires
Old 07-24-18, 03:49 PM
Yes and see what that does. Have you reset the valves?
Old 07-26-18, 07:32 AM
G
Took off the ground wire seems to run better still has a vibration.question now what do i do with the ground wire.do i leave it off or put it back on .I did't readjust the valves thats why I took it in and they told me it was the governor they said they adjusted them.For some reason I just can't seem to get them right
Old 07-27-18, 12:07 PM
G
marbobj did you see my reply
Old 07-27-18, 04:49 PM
Sorry I hadn't gotten back to this thread. If you know disconnecting the kill wires fixed it, the problem is in the diode in the kill wiring harness. You can just get a new harness with the diode.
Don't leave the kill wires disconnected as a fix, it's only for diagnosis. They are the way you kill the engine safely.
Old 07-28-18, 11:46 AM
G
thanks for everything left them disconnected and I had trouble turning off the engine
