Tecumseh engine swap won't charge the battery
Old 08-24-18, 03:33 PM
B
I swapped out a B&S lawn tractor engine that was broke, with a Tecumseh 10 hp engine. Got it running abut it does not charge the battery. Only has 2 wire from the engine. one red and one green. The green is a kill. The red has only 4 volts on it. model is TVM2220-157081G. Does this engine have a voltage regulator ?
Thanks
Brian
Old 08-25-18, 01:27 AM
cheese's Avatar
No, not normally anyway. At full throttle you want 15 or close. Check AC voltage and see what it is. You may have a bad stator or magnets loose on the flywheel.
Old 08-25-18, 08:35 AM
Geochurchi's Avatar
Hi, have you located the wires coming out from under the flywheel?
Geo
Old 08-25-18, 01:03 PM
B
yes sir, I pulled the fly wheel. Checked everything. and cleaned under the fly wheel. Now it works
Thanks
Old 08-25-18, 01:06 PM
B
yes sir, I pulled the fly wheel. Checked everything. and cleaned under the fly wheel. I was full of dirt and who knows what. Now it works
Thanks
