Homelite HP3127S Pressure Washer Pump Leaking oil from Flange Seal
This PW was also sold under Ryobi 80030/80030A. The oil is leaking from the pump flange seal (pump input shaft), so I want to replace the seal. Problem is I can't confirm the OEM Flange Seal P/N GUGO92365 that I have.
Only IPL for Ryobi 80030 shows the Flange Seal p/n above, but this part is not shown on the IPL for Ryobi 80030A, or Homelite HP3127S . The OEM PUMP Replacement p/n for the *all* models PW is 985660001 . I think this has an FAIP PK16095 pump, but I cannot confirm. There is a sticker with numbers on the pump I can post if that would help. Can anyone confirm/have the Pump Flange Seal p/n for Homelite HP3127S ?
