Is this the right starter switch button for my 850?
Working on tractor and somehow fried the starter switch button. When I press it, it only spits out 4 volts to the solenoid.
Here is a picture of it... I broke one of the screw terminals off when I was taking the wire off.
Will this TSC button work on my tractor? Thanks.
https://www.tractorsupply.com/tsc/pr...w?cm_vc=-10005
Hey thanks for the quick response PJ!
They didn't have that, one so I got this one... I assume it will also work, based on what you said.
Thanks again!
https://www.tractorsupply.com/tsc/pr...mbly-189158m91
Thanks again!
Does your tractor not have a starter switch on the transmission cover? When I bought my NAA it just had a regular push button starter mounted on the body but it was supposed to have one on the trans cover. The one on the trans cover is a safety switch and won't allow you to start the tractor unless it's in neutral. I bought the correct switch at a local tractor parts store 20-25 yrs ago.
Thanks PJ, yeah I got that one and it works.
MarkSR someone cut the wire and disabled the safety switch on the transmission cover a long time ago. I've been driving it 10 years and only just recently realized what that thing was, when I started researching this switch button thing.
It's not a big deal to replace and rewire the safety switch.
You might want to buy an IT repair manual for your year/model tractor. I bought one at Tractor Supply about 25 yrs ago. I only use mine occasionally now but used it a lot when I first got it.
