Carburetor for Tecumseh 10 hp generator
Old 10-18-18, 04:59 PM
L
Question Carburetor for Tecumseh 10 hp generator
I have a Coleman Generator that has a Tecumseh 10 hp engine in it, I need a carburetor for it and cannot find one anywhere.
The unit is a 1074H2V.
The engine serial number is 63530616.
We are recovering from hurricane Michael and I need this generator very badly.
Any help is greatly appreciated.
Thanks, Larry
Old 10-18-18, 05:51 PM
G
Received 11 Votes on 11 Posts
You haven't stated the problem with the engine, will it start, start but only run on choke, not run at all etc. Have a good one. Geo
Old 10-18-18, 06:47 PM
L
Will only run on choke for short time and very hard to get running at all. Not getting fuel to engine.
Old 10-18-18, 10:25 PM
cheese's Avatar
Received 57 Votes on 52 Posts
Old 10-19-18, 07:28 AM
G
Most likely the main jet is clogged, clamp off the fuel line and remove the bowl nut which is the main jet, it has a hole down the center one across the bottom and a very tiny hole near the top that is almost invisible it is right next to the top threads, I clean it with the wire from a twist tie, make sure all the holes are clean especially the tiny one and you are good to go. Have a good one. Geo
