Yamaha 350 Warrior
's Avatar
05-22-01, 08:11 AM   #1
My brother owns a Yamaha 350 Warrior four wheeler.
The oil drain plug is seized and he needs to know what he can try.
The case and the plug are both believed to be aluminum.
Can heat be used? If so, what precautions should be taken?
Joe_F's Avatar
05-22-01, 09:00 AM   #2
Joe_F
Try drilling into the plug and then removing it. If you mess up the threads, you can tap new ones most likely. Is it stripped or stuck?
If you really mess up the threads, then go to the auto parts store and get the rubber push-in drain plugs from Dorman/Motormite and put them in place of the metal one. Buy a strip of 'em, and change them every oil change .
Good luck.
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
05-22-01, 08:05 PM   #3
Hello: Nooner
Joe has offered you some good advice and an idea for an alternate replacement oil plug.
Although I do not want to insult you nor anyone, have you considered the possibility the plug could be counter threaded? Granted, not likely but possible.
If the head of the plug is rounded off too much, drilling into it and removing it with an easy out may be another possibility.
If you do manage to unscrew it out, cleanup the pans threads with an item called a "Thread Chaser." These are available in both US and Metric threads and are at all auto parts stores.
Good Luck,
Tom_Bartco
Accurate Power Equipment Company.
Small Engine Service and Repair Technician.
Personal Quote:
"If it ain't broke, don't fix it!"
