Husky leaf blower won’t run
Old 11-11-18, 07:52 AM
My husquvarna 350 leaf blower will not run.
When I put gas in the carb it will run until it burns off. Will not suck gas up.
Did replace filter.
Old 11-11-18, 08:25 AM
Received 6 Votes on 6 Posts
would check the gas lines, you may need to replace or rebuild carb.
Old 11-11-18, 10:00 AM
Received 3 Votes on 3 Posts
Replace the gas lines and the spark arrestor.
Old 11-16-18, 08:58 PM
Sounds like the carb pump diaphragm may be bad. I have a BT150 , which is similar to the your BT350 . The carb on that blower is a Walbro WYA which uses 2 diaphragms , one for metering and one for a fuel pump. You can rebuild the carb easily and get the Walbro OEM kit for about $10-15 on ebay. Replacement of the whole carb is about $80.
As mentioned below check your fuel lines for holes/leaks . A pin whole will suck in air. Also check the carb to crankcase gasket and that the carb mounting screws are tight.
