Need help on Timecutter z4200 blades won´t engage
Old 11-16-18, 02:58 PM
D
While mowing, the blades stopped working. I disconnected the clutch power connector, tested, and get 12v with the mower on and switch pulled up. I also noted the belt on the clutch was falling off which led me to inspect the deck. There, I found the idler arm loose as the bolt that holds it to the deck had snapped. So what happened? I obviously have to replace that bolt but is the clutch gone? I do not see it move when I engage the switch but I feel like I hear a slight clunk (if that means anything). I am not a mechanic so any help is greatly appreciated. Thank you.
Old 11-16-18, 06:48 PM
cheese's Avatar
Received 112 Upvotes on 102 Posts
The clunk you hear is the clutch engaging. It's fine according to your description.
