Tecumseh (Craftsman 143 626032)
Old 12-23-18, 02:16 PM
Bore is 2.75 in. And horizontal crank.
would the ignition timing (BTDC) for ECV 110 (.035 in) be the same as bore size match?
Old 12-23-18, 03:55 PM
Received 3 Votes on 3 Posts
I really don't understand the question the ignition timing on most small Tecumseh engines is set by the flywheel key so bore would not be in the equation. Have a good one. Geo
Old 12-23-18, 10:21 PM
cheese's Avatar
Received 20 Votes on 17 Posts
There is no correlation between bore size and timing.
Old 12-24-18, 08:07 AM
The answer I am looking for is .08 in.
Thanks for your time with the responses .
12 Fergus.
Old 12-24-18, 12:34 PM
cheese's Avatar
That makes no sense. Timing is measured in degrees, not inches.
Old 12-26-18, 11:08 AM
Received 2 Votes on 2 Posts
To correctly set the timing on a Tecumseh adjustable points ignition you must set the stator to break open at the correct distance BTDC:
https://imgur.com/WHOwh1Y
