weep hole
's Avatar
05-24-01, 08:55 AM   #1
My 8 HP techumse engine's carborator is leaking around the weep hole. I don't know what a weep hole is (My DAD told me). What does this mean?
Joe_F's Avatar
05-24-01, 09:05 AM   #2
Joe_F
The weep hole is like a vent hole.
's Avatar
05-24-01, 11:13 AM   #3
weep hole
Thanks a lot for the info. Is that a vent for air or gas?
It is located on the bottom of the carb. In any event, I just put a shut off valve on the gas line and turn it off when I'm finnished mowing so the gas wont leak out while it is sitting. The mower (old snapper I bought for $225) runs fine. Hey, thanks again.
Joe_F's Avatar
05-24-01, 01:12 PM   #4
Joe_F
Wow . That's a lot of dough for a used mower. I usually get 'em for nothing. Lol. The last one I gave to my grandfather just had a jammed starter cord which I fixed and then I tuned up the mower and serviced it. Two years later it's still running and I use it every week.
Problem with Sears mowers is the steel deck. They rot out. So, I will transplant this motor, handle and wheels to the deck I have from my parent's 1979 model Craftsman which the engine seized when a tree stump was hit. Ouch!! We replaced the deck with a Sears service part and then I saved the unit when the motor died.
I will do that swap after the season is out.
Good luck.
's Avatar
05-24-01, 01:44 PM   #5
thanks
Thanks man
