Ariens 824 sno blower35 years old approx
Old 01-29-19, 08:00 AM
B
Received 1 Upvote on 1 Post
I cannot keep it running. Now!It runs great but quits the minute it sees sno.It supposedly as all small engines do an---AIR FILTER.I have all the parts books for this 824, Where in Gods green earth am i missing the "air filter"??ITs not in the manuals.All small engines have air filters i thoughtAnyone point me in the right direction thank you much bob s
Old 01-29-19, 08:04 AM
G
Received 28 Upvotes on 27 Posts
Snow blowers do not have air filters, the snow gets through to the filter and melts then when the engine is shutoff it re-freezes and blocks the air flow. Have a good one. Geo
Old 01-29-19, 08:29 AM
B
thank you geogrubb -----still quitting on me and having no idea whats the matter with it.Anything to look for maybe? bobs
Old 01-29-19, 12:28 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
The usual problem is a clogged carburetor.
Old 01-29-19, 12:35 PM
B
Just got done removing carb- sprayed it all over inside,and out, with carb cleaner.It will run when you put a baster full of gasoline in the cylinder. Stops dead then. And nothin starts it, til i put more gas in the cylinder.The bottom bowl adjustment is 1-1/2 turns out and Air is the same 1-1/2 turns out. Its got fire. Carb was cleaned --out and went back together like it was supposed too? Choke on. It still won't fire any more tips.PLease! i need them thanks again bob s
ps;Is the adjusting screw on the bottom about right?????
Old 01-29-19, 02:46 PM
G
The bowl nut has a tiny hole neat the top that gets clogged I use the wire from a twist tie to clean it, make sure it is clean as well as the one across the bottomm and down the center. Have a good one. Geo
Tec Bowl Nut Photo by geogrubb | Photobucket
Old 01-30-19, 05:47 AM
B
thank you geogrubb,I also as i was ready to put the carb back in place.----here was a tiny short tube that was laying very on the work bench, very very small in dia and it had one end open on it bout 1/4"to -1/2"long???????,.Where would you see to order a new rebuild kit? thanks again Geo bob s
Old 02-03-19, 06:31 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, it would be nice to know what type of engine you have on that 824 .
Geo
Old 02-04-19, 07:51 AM
B
Thanks Geo!But i got it making the trip now around thru the sno..All good at this point -Is Tecumseh engine .I live right here n the town that built the Tecumseh engines bob s
Old 02-04-19, 07:55 AM
Geochurchi's Avatar
OK, same as my 824, tuff to kill those.
Geo
Old 02-05-19, 03:53 AM
B
Thumbs up
tuff to kill is right Geo thanks bob s
Old 02-26-19, 03:05 PM
C
I had the same problem with the 8hp tecumseh in my 1970s Ariens. $12 replacement carb from eBay fixed it. No adjustments needed, just bolted it on and put the blower back to work.
Old 02-27-19, 07:14 AM
B
Thank you much Critter! for your tip. I can use it. bob s
Old 04-10-19, 11:41 AM
B
Tecumseh engine on my 824 sno blower
