Snow Blower with Tecumseh 37000 Starter Motor
Old 02-18-19, 05:56 PM
I have a snow blower with a Tecumseh 37000 starter motor.
The motor mounting bracket broke off the motor. (see pic) Motor is good, gear is good. Haven't had it apart yet. Watched a couple YouTube videos.
I'd like to try welding it, but.....
Can the windings (stator) be removed from the housing?
Name:  Starter Motor.jpg
Old 02-18-19, 06:02 PM
Received 3 Votes on 3 Posts
Do you have a wire feed or a stick welder?
Old 02-18-19, 07:10 PM
Wire feed.
I altered my photo. Bracket was attached where the green dots are.
New replacement motors have the bracket welded where the redstripes are. Much better.
EDIT: After watching a couple vids, it doesn't look too technical to disassemble the thing. Maybe do that in a couple days when I get time.
Old 02-18-19, 09:11 PM
To weld down the the red lines you have drawn you'd need it disassembled. It would have a lot of heat on the case. To spot weld on the green dots in that size weld wouldn't transfer that much. You might get away without disassembly.
Old 02-19-19, 05:41 AM
Received 33 Votes on 28 Posts
The insulation (varnish) on the wire used in the windings of the motor will melt at a low temp.I would not attempt welding the mounting bracket unless I could remove both the stator and rotor. Looks like you could use a couple of aircraft hose clamps to attach the bracket to the motor.
Old 02-21-19, 01:24 PM
Clamps! Now there's an idea. Wonder if 2 or 3 hose clamps would hold. The motor shouldn't slide, since the 4 little 'bumps' on the bracket fit into the motor housing.
I was thinking of using 2 muffler clamps. BUT, there is less than 1/8" between the bracket and the engine block. Maybe weld 2 "L" shaped pieces to the bracket. Then clamp it with a "U" bolt. (I'm thinking durable).
Still have the recoil/rope. Hoping that doesn't break.
We're having a very snowy winter. All the stores are sold out of snowblowers.
