Mower Ignition Coil Problem?
Old 05-18-19, 07:09 PM
G
Received 2 Votes on 2 Posts
Hi Guys,
Earlier this spring I had to replace the coil in my 6.5hp Tecumseh engine (no spark).
After replacing it I can start on the first pull again. When its cold.
Once it warms up, its reluctant to re-start. I have to pull very fast to get it to fire up, which it does, and runs fine.
Could it be too little gap on the coil (or too much)? I measured the gap from the old coil before I started and set the new one the same.
Anyone run into this before?
Old 05-18-19, 11:28 PM
cheese's Avatar
Received 54 Votes on 49 Posts
Not likely, what model? Does any puff of smoke come out when it starts warm? Possible valve clearance issues.
Old 05-19-19, 10:53 AM
G
No smoke that I've seen.
Its a Toro, about 5-7 years old.
Old 10-04-20, 12:24 PM
G
Solved
Well, the mower slowly died while using it.
I did some checking and I had no spark so I replaced the coil, again.
It definitely starts and runs better now.
Must of been a bad coil to begin with.
Old 10-06-20, 11:38 PM
cheese's Avatar
Glad you got it figured out.
