Honda lawn mover shuts off after it starts
Old 09-29-19, 08:23 AM
Y
I have honda hrr216k9vkaa walk behind lawn mover
with honda gcv160 auto chowk system - it is about 3+ year old ( so out of warranty ), filter is clean, changed the oil and spark plug, still same issue - why ? How to fix it ??
Old 09-29-19, 08:43 AM
A
Received 72 Votes on 65 Posts
How long does it run before it shuts off? If in the 5-10 minute range I would probably suspect a dirty gas cap, specifically a plugged vent in the cap, or if say 15-20 minutes or so might suspect a coil starting to fail. If less than a couple of minutes though, or almost immediately, I would suspect old gas or a carburetor that needs to be thoroughly cleaned or replaced.
Old 10-05-19, 03:37 PM
Y
runs for about 15-20 minutes and then dies and wont restart, today i have tried to replace it with new oem honda carburetor and then it does not start at all, i have also tried to check gas cap by draining the fuel out in tub to see gas flows well when cap is on ( not sure any other way to check gas cap ), your guidance will be highly appreciated
Old 10-09-19, 02:42 PM
cheese's Avatar
Received 55 Votes on 50 Posts
Check for spark when it dies, could be a bad coil.
