Kohler back fires though carb
Old 10-13-19, 08:27 AM
R
Kohler CV490. Initially gas would shoot from the exhaust when starting, but it ran okay. Now it will not start, but backfires through the carb when trying to. I have installed a new carb and plug, and confirmed spark at the plug. Also you can feel compression at the plug port, and smell gas on the plug. Suggestions? Thanks!
Old 10-13-19, 09:37 AM
Received 20 Votes on 19 Posts
With the new carb the gasoline out the exhaust stopped and the backfiring through the intake started? Or is there a different order of events?
Old 10-17-19, 04:51 PM
R
There was backfiring with both carbs. Thanks!
Old 10-17-19, 06:03 PM
It could be the valve lash is off or a stuck intake valve, or a flywheel key sheared. The key would allow the flywheel to advance on the crankshaft messing up the timing.
Flooding an engine can get a backfire like that, but I would check the valve lash first.
Old 10-17-19, 09:07 PM
cheese's Avatar
Received 56 Votes on 51 Posts
Generally that's caused by a sheared flywheel key on these engines.
Old 10-18-19, 04:48 AM
B
Received 113 Votes on 99 Posts
Have you checked the gap between the ignition module and the flywheel? Should be about 0.010 inches.
