Won’t run unless I feed it gas thru the carb
Old 11-20-19, 12:32 PM
C
Tecumesh 7 hp. New carb installed. New gas. Only runs if I feed it gas thru the carb. Seems to be not pulling fuel from carb
Old 11-20-19, 12:40 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
Is the carb gravity fed or does it have a pump? Gravity fed may have float stuck and take bowl off pull float down.
Old 11-20-19, 12:46 PM
C
There is fuel in the bowl
Old 11-20-19, 03:39 PM
P
Received 962 Votes on 883 Posts
It's a fuel problem. New carb or not it's still a fuel problem. It is possible the new carb is not working, especially if it's a cheap aftermarket one. It also could be bad or dirty gas. You said "new gas" but did you replace the fuel line and clean the inside of the fuel tank? All it takes is one fleck of varnish or dirt to clog a jet in the carb.
