Husqvarna mower won't start
Old 11-20-19, 06:55 PM
T
Husqruvana M-zt 52 zero turn mower. 28 hp Briggs and stratton model 49L977 type 1635G5 code 130109YG
Old 11-20-19, 07:00 PM
Received 1,599 Votes on 1,473 Posts
Welcome to the forums.
Maybe a dead battery ?
Gas tank could be empty.
Old 11-20-19, 07:14 PM
T
I starting cutting my lawn when the engine stopped. I have replaced the plugs. checked the magneto coils, both checked 4.11 with the meter. I checked the flywheel key. i replaced the fuel filter and fuel pump.
The engine will spin and fire then not run. I replaced the fuses in the ignition system. Cannot find the 7.5 fuse.
I have gas in the cylinders and have a good spark.
Confused as to why it will not run
Old 11-21-19, 07:35 AM
Received 20 Votes on 19 Posts
Was it running well up to the time it quit and it just stopped suddenly? Try disconnecting the kill wires (small wire) from both coils and see it will start and run. If it does that points to the kill wire diode. This is based on you getting a spark now, which would eliminate safety switches.
