engine starts, but does not stay running
Old 06-04-01, 12:21 PM
I have a MTD Product with a Briggs & Stratton engine. It is only 1 year old. It was running fine, then it just stopped. During my attempt to repair the lawnmower, I tipped it over and oil started coming through the carb. I did discover that the plastic tup that runsn from the carb bowl to the manifold was cracked. I don't know if I cracked or it was cracked all ready? so I used JB weld to fix the crack. I put everything back together, and the lawnmower fired right up. I got about half way done with mowing my lawn, and it died again. Now it is doing the same thing as before.
Please help!
Old 06-04-01, 04:15 PM
small engine repair
can anyone help
Old 06-04-01, 08:09 PM
Sharp Advice's Avatar
Admin Emeritus
Hello wwjd77555
About the suggestion to correct this problem is to replace the damaged part with a new part. You can get it at any local lawn mower repair shop in your area.
Remove the damaged part carefully. Make a mental note or a hand drawing of exactly every part you remove {{{to get to the damaged part}}} how that part came off {{{including the damaged part}}}, where it was located and how it was attached to another part.
Good Luck,
Tom_Bartco
Accurate Power Equipment Company.
Small Engine Service and Repair Technician.
Keep in mind my company no longer services nor repairs lawn and garden powered equipment. However, the help I can offer you is based upon my prior years in this industry with this type of equipment.
Trackbacks are On
Pingbacks are On
Refbacks are On
