Hard to crank
Old 11-22-19, 05:25 AM
pugsl's Avatar
Received 27 Votes on 26 Posts
Hard to crank
Have a briggs 24 HP v twin model 445677 that is hard to crank. New starter and battery. I have found out that if I hand turn crank till piston is just over TDC it will crank and start.Am wondering if there is a compression release in this model.I think it is only on one cylinder as it turns over will till I get to hard part.
Old 11-22-19, 01:51 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Adjust the valves. This should solve your problem.
Old 11-25-19, 04:08 PM
pugsl's Avatar
Just got to doing the valves and starts like a champ. Thanks a lot.
Old 11-26-19, 12:05 AM
cheese's Avatar
Great, glad you got it!
______________________
Old 12-10-19, 06:56 AM
Received 1 Vote on 1 Post
How do you adjust the valves on this engine? Is it easy to do? I am having the same problem with a Twin Briggs
Old 12-10-19, 03:15 PM
pugsl's Avatar
I just took the valve cover off and think 15mm wrench and 30 torques. I need to redo mind as I didn't get the clearance right. Left one to loose and still hangs up a little.
Old 12-10-19, 05:32 PM
cheese's Avatar
