2750 popular chain saw
Old 01-19-20, 10:57 AM
G
I have a 2750 poulan chain saw that the chain gets tight while cutting to the point it will stop.Then the next time it will loosen up
Old 01-19-20, 11:00 AM
Tolyn Ironhand's Avatar
Received 352 Votes on 304 Posts
Sounds to me like the bar is not fully tightened and the adjustment screw is either loosening or tightening from vibration.
Old 01-21-20, 01:39 PM
D
Received 2 Votes on 2 Posts
Have you taken the bar off and run the saw to check and see if the oiler is pumping oil. If not the chain is getting hot and seizing on the bar. If it is pumping oil clean out the groove on the bar to make sure the oil is getting to the bar.
Old 01-22-20, 04:37 AM
P
Received 914 Votes on 841 Posts
With the saw off pull the chain around. It should move smoothly and easily for it's full length. If the chain got kinked or the groove in the bar got nicked or bent it can cause binding. When the metal gets hot and expands it could cause it to bind worse.
Old 01-22-20, 04:52 AM
T
Received 41 Votes on 39 Posts
I agree with dreamen to a large extent.
Old 01-22-20, 05:13 AM
Yes, I agree too... that was my first thought! Is the Primer/Oil Pump working?
Sometimes they get "clogged"... remove and clean all gunk off!
Old 01-22-20, 06:55 AM
G
thanks guys I did have a problem with the oil pump tried to get a new one and 3 times I ended up with the wrong one
Old 01-22-20, 08:39 AM
W
Received 34 Votes on 31 Posts
If you are using a roller nose bar, check the nose sprocket for clogged sawdust.
Old 01-24-20, 05:14 PM
G
any ideals where I can Buy a oil pump
Old 01-24-20, 10:20 PM
cheese's Avatar
Received 55 Votes on 50 Posts
From a quick search, it looks like your pump should be replaced by any of these numbers
530029834 , 530029835 , 530014410 and/or 545036801.
