B&S 16 HP Vanguard
Old 02-11-20, 12:18 PM
Geochurchi's Avatar
Received 25 Votes on 24 Posts
B&S 16 HP Vanguard
Hi All, motor runs great, itís relatively new, problem is that when shutting it off it continues to run for maybe 5 seconds after the ignition is turned off, upon further inspection I noticed a terminal and wire hanging loose just under the fuel pump location, there is a wire connected to one side and nothing to the back side, itís has a tab that looks like a wire should be connected to it underneath the housing, could these be the reason for the delay in turning off the ignition switch?
Geo
Old 02-11-20, 01:16 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Possibly. Sounds like the engine is shutting down via the anti-backfire solenoid instead of the actual kill wire.
Old 02-11-20, 03:33 PM
Geochurchi's Avatar
Cheese, any idea if there should be a wire under that cowling ? I guess I should try and remove it and check, where is the anti backfire solenoid is located?
Geo
Old 02-11-20, 05:56 PM
cheese's Avatar
There should be a single black wire going to the coils to kill the ignition, then a single or possibly two wires coming out together into a connector for charging (probably going to a regulator on the side) and if it has an anti-backfire solenoid, it will have a wire going to that, possibly two, depending on which type it has. It would be screwed into the carburetor bowl.
Old 02-12-20, 12:29 PM
Geochurchi's Avatar
Problem solved after some disassembly. manufacturing defect.
Geo
Old 02-12-20, 06:44 PM
cheese's Avatar
Glad you got it.
_________________________
