Help me identify this carburetor please.
Old 05-22-20, 02:50 PM
R
This is on... well, it's off now lol... an Ariens 911082 lawn mower.
I've googled the numbers on the carb and I'm having no luck.
The bottom of the bowl, not pictured, it says Tecumseh on it.
All i really need is the plastic bit to the right. The fuel inlet thingie. You can't see it in the picture, but it's cracked.
I saw on Amazon they're selling new carbs with filters, plugs, gaskets etc for super cheap, like $15. But I can't match mine up.
Number on the carb: F 5033 A81
Old 05-22-20, 03:03 PM
Marq1's Avatar
Received 237 Votes on 224 Posts
Caution about thoes super cheap China POS carbs, you get what you pay for and if you do a little searching on the site you will find more people end up pitching them and then buying OEM!
Old 05-22-20, 03:54 PM
Received 9 Votes on 9 Posts
What is the number on the engine - like HM 70, HM 80 ? Try that number to chase the inlet fitting.
Old 05-22-20, 04:04 PM
Received 741 Votes on 696 Posts
The white right angle piece of plastic is the fuel inlet fitting. The part number # 640363.
Google that number and you'll find many places that carry it.
I see several sellers on Ebay selling it from $2 to $5.
Part on ebay.
Old 05-22-20, 04:05 PM
R
I found the carb and the part number.
Next question, does the inlet fitting just press in? Tried turning the part still in the carb and it won't budge, with minor force.
Old 05-22-20, 04:11 PM
R
Pjmax, wrong part number.
If you look at my picture you'll see they are not the same item.
Old 05-22-20, 04:21 PM
R
I see now, it is pressed in. I'll have to make a mini puller and go from there.
Old 05-22-20, 04:46 PM
cheese's Avatar
Received 30 Votes on 25 Posts
As much as I hate to give props to chinese anything but I have to sya I've had pretty good success with their cheap carburetors. OEMs are made in china too much, maybe most of the time.
joecaption voted this post useful.
Old 05-22-20, 05:08 PM
R
@cheese I agree with you.
Old 05-22-20, 05:24 PM
Received 54 Votes on 49 Posts
I've bought at least a dozen of those aftermarket carbs and never once had an issue with them.
Most often they come with a new air filter, gaskets, fuel lines, some even have a spark plug and cost less then half of of what just the OEM carb. cost.
Feeling lucky, you may just find that plastic fitting in any box store in the plumbing dept, where all the small bins are.
I have all the stuff to do it so if it was mine, I'd drill it out, tap it, and use a brass street barbed elbow.
Old 05-23-20, 12:04 AM
cheese's Avatar
631807 may be the tecumseh inlet elbow part I believe.
