Honda GCV160 runs ok but cant restart
Old 12-08-20, 09:49 PM
B
I had a problem with the mower ...ended up replacing carb and the auto choke heat pin after that it started and ran for 3 minutes then die ...pull spark plug and found. NGK BPR5ES so i changed it to a 6 ....now it seems to be running ok but when i shut it off it will restart until it cools down
Honda
Old 12-09-20, 04:49 AM
P
Received 876 Votes on 806 Posts
First try loosening the gas cap and see if the problem still occurs. Also, when you get it running go ahead and mow for 10 or 20 minutes. Does the engine start to run rough or quit when it gets good and hot?
Old 12-09-20, 03:09 PM
cheese's Avatar
Received 54 Votes on 49 Posts
Try tipping the mower with the carb side up for a couple seconds, then starting. If it starts, it's not getting enough fuel to restart.
