Briggs Stratton Stratton blow by
Old 05-03-21, 05:26 AM
B
Briggs and Stratton engine 14.5hp. I have checked timing marks . I have set valve clearance s but it still blows back out the carburettor . ?
Old 05-03-21, 06:17 AM
T
Received 23 Votes on 19 Posts
Blown head gasket or burnt valve?
Old 05-03-21, 05:41 PM
cheese's Avatar
Received 55 Votes on 50 Posts
Do the rocker arms both move about the same amount when they open? Often a lobe wears off the cam and causes this effect. I've had two already in the past month or so. Blowing back out the carburetor isn't blowby though. A blown head gasket, damaged cylinder/piston, or worn out rings would cause blowby which is combustion gasses entering the crankcase. Those things won't cause pressure to come back through the carburetor thoug.
Old 05-04-21, 06:09 AM
T
I have to disagree with Cheese, the blow by into the crankcase will shoot right into the carb through the PCV port. It will also create a ton of smoke from the oil vapor that accompanies it if it's able to run. Ask me how I know....
Old 05-04-21, 07:35 PM
cheese's Avatar
That would be very severe blowby, but yes that's possible.
