Briggs won't start without starting fluid
Briggs 130202 on a Dynamark rototiller. Wouldn't start because of no spark. I removed and cleaned rusty flywheel with fine sandpaper. Also removed and cleaned coil the same way. Removed and cleaned very corroded points the same way. This was not a real good and proper cleaning of the points. The motor now starts by putting starting fluid in the cylinder and pulling 6 or 8 times. Will not start normally on just gas. I let it run for a half hour with Sea Foam in gas.
Is the lack of starting because of weak spark from improperly cleaned points, bad condenser or weak coil? I intend to use a file on the points tomorrow for a better cleaning. I have some extra Briggs motors around. Will parts from them fit or is part numbers critical? Will coils from other motors work if flywheel is same diameter?
Sounds more like a fuel issue, when using the starter fluid does it run on it's own or are you constently shooting starter fluid into the carb?
I started it with starting fluid and let it run for over a half hour with no problem except for a little roughness which I am guessing is from dirty carb and carbon buildup. Hopefully Sea Foam will work on that. I tried tilling a little and it worked without stalling or noticeable change in engine.
