Toro Line Trimmer
Toro Line Trimmer
I have a Toro Commercial Grade Line trimmer TO 30900 I bought new in 1981. I had a scare yesterday, as it up and died iwth no restart forthcoming. I found the problem in a cracked plastic weld I did years ago as fuel line grommets and or fuel tanks were obsolete by then. Before I found the crack though I was checking the carb for other smoking guns, and although I saw none, I checked some Toro part numbers for the two diaphragms that pump the fuel into this baby. They and most everything else for this trimmer is NLA. It has a Kioritz 21 cc 2cycle engine, Is there a source for parts for this engine anywhere?
Jacks is on my Google master list, and I checked them right away. Tractor Supply sells some kioritz powered mini tillers which might be a source for me.
Yamabiko corporation owns Koritz, Echo and Shindaiwa so it's possible you will find a parts cross reference. I needed a carb kit for a Mcculloch trimmer iit had a Koritz engine and used the same carb as an early Echo. Have a good one. Geo
Hey Geo, I got a part number of 125302-15330 (called a KwiK KIt) Echo Brand. The diaphragms in the photo sure look like mine. Who did you use a source for YOUR parts?
Hey Geo, I got back to Jacks with the Echo Part number, and it superseded just once to another number. I found out that Kioritz was bought out by another company who also bought Echo, So I guess Echo must have liked the carburetors that Kioritz was building and used them for MANY succeeding years. So I have all the gaskets and parts on the way to me that hopefully will replace what I have when I need it!
thanks for your reply to me!
