back firing
My go-cart has the 5 HP B&S fun power engine and it has started back firing when under full power. Scares the &($^#^%$ out of the kids when it pops. Any suggestions on where to start to fix the problem.
Received 7 Upvotes
Several Possibilities
Hello Sandy2000
Your absolutely correct. We can't have the engine backfiring and scaring the &%!$#@$! out of the adults...ooops...kids...hahaha
Most likely cause is an engine running too lean. Try riching the fuel mixture for both low speed and high speed.
About an 1/8 of a turn counterclock wise on the left {L} fuel screw and 1/4 turn out on the right screw {H}
A restricted fuel supply will also need to be checked for. This can range from flow from the tank, low fuel level in the carb bowl or a restricted carb.
Check the spark plug also. Be sure it's the correct one for the engine. A plug that runs too hot can cause minor lean burning.
Also check the muffler for good exhaust flow. A damaged or overly rusted muffler may have internal damage causing a restriction. This can cause several problems, one of which is excessive engine heat.
Other possibilities could be engine timing if the flywheel was removed prior, incorrect valve settings, an overly rich high speed fuel mixture {which would produce black smoke} or an engine running too hot do to a lack of air cooling.
Regards and Good Luck,
Tom_Bartco
Accurate Power Equipment Company.
Small Engine Service and Repair Technician.
Personal Quote:
"If it ain't broke, don't fix it until it is broken!"
Bare in mind my company no longer services nor repairs lawn and garden powered equipment. Rest assured and fully confident, the help I offer you is based upon my prior years in this industry, with this type of equipment and is specific and accurate to the best of my knowledge...
Tom_Bartco
Personal Quote:
