Hi everyone. I was hoping to get some input in a string replacement issue on my Craftsman WC2200 I bought this summer.
So i didn't really have an issue the first time (and maybe the second time) I re-strung the trimmer, but I cannot get it to work this time.
I understand that you're supposed to line up the bump head arrow and the arrow on the main head and stick the string in a few inches.
But from a youtube video i saw, the string is supposed to stick and not pull out once it goes in far enough.
My problem is that now matter how short or how far i stick the string in, the string always just pulls right out with minimal effort.
It's causing the string to just unwind with any amount of twisting the head does when revving up the trimmer.
As far as i know, the head isn't depressed or anything that would let the string just come out.
I'm not sure if my head is messed up already or if i'm just doing something wrong.
Can someone advise if this is a common issue with the trimmer or just a string replacement issue?
I've seen some heads where the line does stick in the hole but on others and with different profile line but other do slip out easily. I push in on the line and start turning/winding and the turns on the drum help hold the line in place.
Pilot Dane I'm not exactly sure, but i think i bought Shakespeare .095 in. I got from Lowe's with the last trimmer i had. And i actually just checked the manual for the line specs and it says it takes Hassle Free Xtra Quiet Spiral Line 0.110 in.
Well, that may be the first thing to get right i guess. Lol. I just assumed any line would work.
beelzebob This is what it says. And i did everything like it said. Probably won't help unless i get the right line first though.
Before I was just searching google for WC2200, the model shown on the trimmer, and manual. But i'm not sure if it's the right manual or not because it was a direct link. But this is directly from the product page.
Alright. So i feel like a moron. The line is the right size i found, but i wasn't twisting the bump head the right direction. I was supposed to feed the line and twist the bump head COUNTER CLOCKWISE, and i was twisting it Clockwise while depressing the bump head (because that's the only way it will twist clockwise) So i just wasn't twisting the bump head the right way in the first place. My bad, and should've checked the simple things first.
This trimmer is about 4-5 years old. Has been running well for the past 5-7 weeks. Same gas with stabilizer. Hit the gas and it hesitates and does not respond well when a surge is needed for power. It was manufactured by the Husquavarna group. Need to know some good steps? Adjust carb? Single screw.
Add how much Seafoam to tank directly? Appears the gas tank on the WeedEater looks to be about a quart?
Need some good tips to try. Noticed starting has been challenging. ThanksRead More
My weed eater wouldn't start and I basically rebuilt it. New carb, carb insulator, spark plug air filter, fuel lines, fuel filter. I even cleaned out the intake behind the muffler and the spark plug hole somewhat. It tries so hard to start but it just putters for a few seconds and dies. Does anyone have any idea what could be the problem?
Also, I tried to start it without the muffler and still a no go so the muffler isn't the problem either.
Read More
