Honda tractor deck adjustment
Old 05-10-24, 04:36 PM
G
Honda 3011 cuts way to short although I have deck adjusted all the way up.PLEASE HELP
Old 05-10-24, 05:25 PM
Received 4,057 Upvotes on 3,640 Posts
Welcome to the forums.
Cutting height: 1.0, 1.5, 2.0, 2.5, 3.0, 3.5 in (Approx.)
According to the manual the tallest cutting height is 3.5".
Have you measured what yours is cutting at ?
Honda 3011 owners manual -pdf
Old 05-10-24, 10:23 PM
cheese's Avatar
Received 149 Upvotes on 136 Posts
Bent blade, low tires, disconnected deck linkage, something bent, bad spindle bearings, could be several things.
Old 05-11-24, 04:13 AM
B
Received 310 Upvotes on 275 Posts
Have you made any changes to the mower like changing blades or tires?
Old 05-11-24, 07:50 AM
B
Are mower deck wheels adjusted for selected cutting height?
Old 05-12-24, 05:37 AM
G
Mower deck
yes the wheels are adjusted down. With pto engaged the blade is at about 4 inches yet it still cuts to short. I hate raking. CONFUSED
Old 05-12-24, 10:28 AM
B
If blade height changes with between PTO on/off there is a problem with the mower deck, possibility blade spindles. With the mower on level ground, check each end of each blade on the mower deck for same height every 90 degrees in a single rotation of each blade and report findings.
Old 05-13-24, 12:15 PM
G
Mower deck
everything checks out good.maybe that's all it will do.deck is as high as it can go
Old 05-14-24, 05:29 AM
B
Is this a new issue?
Old 05-19-24, 10:23 AM
G
Mower deck
no it's older
Old 05-19-24, 04:24 PM
B
How do you know you have the correct size tires on your mower?
