Ramps for changing tractor blades
Old 06-14-24, 05:12 PM
Received 1 Upvote on 1 Post
I have a John Derre 570.
What small ramps would be suitable for driving up on them to get under and take the blades off?
I see some at Home Depot called - Black Widow Psr295 Plastic Car Service Ramps
Black Widow ramps
Not sure these are ok?
Thanks
Old 06-14-24, 06:00 PM
Received 4,152 Upvotes on 3,729 Posts
Probably heavier duty than you'd need but should work fine.
Old 06-14-24, 07:35 PM
Tolyn Ironhand's Avatar
Received 915 Upvotes on 773 Posts
Old 06-15-24, 04:41 AM
B
Received 322 Upvotes on 284 Posts
Could also place something like cinder blocks or 8x8 wood blocks under front wheels using a wheeled automotive type jack. Jack can be removed for better access.
Old 06-15-24, 05:27 AM
D
Received 291 Upvotes on 230 Posts
Now, I'm not being funny or trying to sidetrack your specific question about ramps, but...
If you have a tractor with a gen pole, that's what I use. I just get a chain on both sides at the front wheels/frame, & pick it up, put a couple of jack stands or blocks, then ease it down to the blocks, yet keeping the chain tight with the gen pole.
Old 06-16-24, 05:35 AM
W
Received 66 Upvotes on 57 Posts
Ramps will obstruct access to the blades from the sides.
sdodder voted this post useful.
Old 06-19-24, 04:19 AM
Received 5 Upvotes on 5 Posts
I agree with wirepuIler- I always jack up the front and use jack stands or blocks under the wheels.
Steve
Wirepuller38 voted this post useful.
