Oil & Gas Mixture ???
Old 06-19-24, 10:31 AM
N
Just bought a New Weed Trimmer. Our old Trimmer ran on a (40 to1) Mixture and the New one runs on a (50 to1) mixture.. Question is it a Big Difference in performance ??
Old 06-19-24, 10:59 AM
B
Received 320 Upvotes on 282 Posts
i would think following the manufacturers recommended gas/oil blend would provide the best tool performance. Why are you comparing apples to oranges?
Old 06-19-24, 11:29 AM
W
Received 23 Upvotes on 18 Posts
A couple of my 2 cycles state the ratio as somewhere between 25:1 to 50:1. I really doubt the slight difference between 40 and 50:1 (0,6 oz) would make any difference,
Old 06-19-24, 12:00 PM
T
Received 112 Upvotes on 100 Posts
I'd follow the manufacturer's instruction. Mixing 50:1 doesn't take more effort than 40:1 and you can get pre-measured bottles.
Old 06-19-24, 12:58 PM
D
Received 290 Upvotes on 229 Posts
I agree to mix as suggested.
Too much oil will make it smoke more, due to burning too much oil. You get fouled plugs & bad performance.
Too little oil is less lubrication. That's not good.
You can take your 40:1 and figure how much more gas to add & just add it to equal 50:1 mixture. I know we got a couple of math guru's here or I am sure there are charts online.
Old 06-19-24, 08:29 PM
cheese's Avatar
Received 156 Upvotes on 142 Posts
I'm assuming you have a partial can of 40:1 mixed fuel and are asking if you can run it. Yes. Use up your old fuel and then mix to the new mixture specs.
NorPlan2 voted this post useful.
Old 06-24-24, 04:00 AM
N
Beelzebob / Apples To Oranges
In the words of the Dealer I bought the Weed Trimmer from after I had gone through the Assembly & Operations Manual.. It's less than Steller.. (Ducar is the Brand Name).. The New Trimmer being a larger CC size, I was reading on oneside 50:1 Gas & Oil Mix and on the otherside 40:1 Gas & Oil Mix.. My side of the 49th we are Litres not Gallons, Canada 4.54 Litres to U.S. 3.78 Litres per gallon.. The Short end of it 40:1 is the Suggested Mix.. Cheers Thank You..
Old 06-24-24, 04:28 AM
B
I was questioning your correlation of different oil/gas ratios to performance. Oil/gas ratios use same units of volume in both the numerator and denominator so the units of volume cancel resulting in only a fraction number. What are your units of performance?
