troy bilt tiller
Old 09-22-01, 11:34 AM
ripperdog3
i have a troy bilt tiller that is probally 20 years old or more. here is my ? i noticed some fluid on housing where the tines are mounted on the shaft but i couldn't find where to add fluid. do you add the fluid to the tranny? i know where you check that i pulled the plug out but nothing ran out. i stuck a small piece of rope in the hole it was some fluid in there. do i need to fill it to it runs out and what type of fluid do i use also i need to change the oil what type would you recommend and grade
Old 09-22-01, 04:59 PM
Sharp Advice's Avatar
Admin Emeritus
Hello ripperdog3
The gearbox will have two Allen head plugs. The lower one is for draining the existing gear oil. I would recommend you do that first. Then reinstall the Allen head plug.
Then remove the upper plug and with the machine level, fill the gearbox with gearoil. Either a 90 or 140 weight gearbox oil will be okay.
The oil your finding on the tines or shaft may be coming from defective seals on the shaft extending out of the lower gearbox.
Clean the area. Run the engine with the tines revolving but not in soil. Check for roundness of rotation. A shaft may be slightly bent and should have a visable out of round rotation.
During this proceedure, if there is seal leakage, gearoil will become visable on the shaft. That seal is the defective part. Both seals should be replaced if one seal is found to be leaking.
Other locations to check for oil leakage is the upper gearbox seals. All locations between housings and componets should be checked. Gaskets may be leaking also.
A service manual for the specific tiller model would be a huge benefit prior to any disassembly. A worth while investment for the Do-It-Yourself person.
Regards and Good Luck,
Forum Moderator
Accurate Power Equipment
Small Engine Service and Repair Technician.
Personal Quote:
"If it ain't broke, don't fix it until it is broken!"
Bare in mind my company no longer services nor repairs lawn and garden powered equipment. The information provided is specific and accurate to the best of my knowledge.
