Ford 100 Lawn Tractor
Old 09-24-01, 10:41 AM
SteelPanther
My neioghbor has a Ford 100 Lawn Tractor and every time he enghages the mower deck it sputters breifly and dies out?? Any suggestions would be greatly appreciated thank you.
Old 09-24-01, 03:32 PM
cheese's Avatar
What engine does it have? A few things could cause that problem. It might be running too lean...try backing the air/fuel adjustment screw out 1/2 turn. Could be water in the carburetor bowl too. Check these things and if problem still exists, let us know more about the machine. Good Luck!
Old 09-24-01, 04:12 PM
Sharp Advice's Avatar
Admin Emeritus
Hello SteelPanther
Cheese offered you some correct helpful ideas.
Also consider checking under the deck and the powertrain for parts that might be binding up, bent, rusted or frozen up do to a lack of maintenance or lubrication.
Examples: Spindles, pulleys, belts, shafts, and damaged blades, etc.
Binding governor linkage may also cause the problem. A too lean fuel mixture do to improper carburetion or restricted carb jets and fuel passages. A fuel restriction and or a dirty or restricted air or fuel filter.
Regards and Good Luck,
Forum Moderator
Accurate Power Equipment
Small Engine Service and Repair Technician.
