smoking b&s 4hp engine
's Avatar
10-15-01, 04:56 PM   #1
4 hp b&s engine smokes a lot. engine hasn't been used for quite a while, but has fresh gas, oil and plug looks good.
can i use a fuel system treatment, or do i need an engine job?
Frosty's Avatar
10-16-01, 10:46 AM   #2
Frosty
what color is the smoke? black or white?
Joe_F's Avatar
10-17-01, 05:57 AM   #3
Joe_F
Black smoke: Running too rich. Carburetor troubles generally.
White/blue smoke: Burning oil. Overfilled crankcase, too thin of grade/wrong oil, internal engine failure.
With either color, the engine will usually run terribly as well.
My guess is black smoke "hasn't run in a while" and some varnish and junk is in the carburetor and it probably needs a servicing.
Need to elaborate more on the problem at hand.
MatthewNadeau's Avatar
10-28-01, 08:59 AM   #4
MatthewNadeau
My 6.5 hp B&S was smoking also, and I noticed a small amount of oil leaking out from the valve case. This only caused the smoking after the engine had been running for a while. I replaced the gaskets and the leak (and the smoke) stopped.
