fuel problem
twainman's Avatar
01-27-02, 08:42 AM   #1
twainman
fuel problem
10hp briggs and stratton model #226437 type#0045 01
just replaced rings and motor runs good except for steady gas drip out of back of carburator replaced needle valve but did not help what should i check out next?
Fisher's Avatar
01-27-02, 10:46 AM   #2
Fisher
You may need to replace the seat as well. Also make sure the
float doesn't have any gas in it too.
Fish
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
01-27-02, 07:27 PM   #3
Several Possibilities
Hello and Welcome Twainman to our Do-It-Yourself Web Site and my Small Engine forum.
As usual, Fisher offers you an excellent advice tip. Replace the needles seat within the carb body. DO NOT overtighten the seat when installing it if it's the screw in type. Seat it lightly but securely.
Another possible problem could be the floats level position. The float must be perfectly leveled to the carb body when held upside down so the needle is seated. If the float is not level, carefully adjust the center tab to correct the level.
Check the float for fuel. if it contains any, the float could have a tiny hole in it. When it fills it sinks allowing the needle to drop and fuel to flow into the bowl.
Another possible problem could be a restricted air vent intake in the carbs body. If the vent is restricted, the engine will run but not as it should and the carb bowl will or could flood.
Regards and Good Luck, Small Engine Forum Moderator,
TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient....
"Accurate Power Equipment Company."
Small Engine Repairs and Diagnostics Service Technician.
Personal Quote:
"If it ain't currently broke, don't fix it, tinker with it or #@$$#!& with it until it is broken!"....
