Snowblower Engine Problem
tmryan's Avatar
03-10-02, 03:49 PM   #1
tmryan
Atlas Snowblower
Does anyone know what make motor powers these vintage snowblowers. I have an old 3.5 horsepower (similiar to the Tore S200) Need to rebuild carb. Can't find model number on motor to identify.
Thanks, Tom
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
03-10-02, 05:52 PM   #2
More Detailed Information Requested
Hello and Welcome Tom to our Small Engine forum.
Knowing the year of the snowblower may help us to identify the engine. Any additional info on the machine may help also.
All engines have the model numbers somewhere. If the engine is dirty, clean it with automotive engine cleaner. Look for stamped in numbers around the carb area or beneath it.
If you also describe the carb, we could determine what type it was and offer helpful ideas, suggestions and rebuilding methods, etc.
Also describe the problem with the engine. May not even be a carb problem.
Summation: We need more detailed info please.
Doing so would greatly improve our chances of offering you corrective, helpful suggestions and advice, technical problem diagnosis assistance, professional repair methods, proceduers and technics, possible parts causing the problem your requesting.
In order to add more detail to this topic, click the reply button and it will allow you to add more detail. When a reply comes back but you still have a question on this same orginal question, use the reply button once again.
Any and all additional detailed information you can provide may help to expose a clue regarding the hearters current problem and help us to determine the exact repair to the problem.
Your assistance in this matter would be beneficial.
Regards & Thanks
Small Engine Forum Moderator
Tom_Bart......TCB4U2B2B.....Company Enterprises
