04-09-02, 05:36 PM
chewychops
I have a rally lawn moer with a tecumseh Engine with a 3.5 hp
it will run if i put gas down the carburetor but then it will stop
gas gets from tank to carb but will not go in to motor took carb
apart clean it good but it still will not start only if put gas down
the carb but then it will stop HELP?
CAL
04-09-02, 06:04 PM
Restricted Fuel Ports
Hello: chewy
Enough though you cleaned the carb, if all the other conditions you described are correct, the carb still has restricted fuel ports and or internal passages.
Another possibility is no fuel is getting into the fuel bowl. The float, needle and seat may still be restricted, not functioning or set incorrectly.
If the engine runs on a prime and dies, the engine has a fuel problem somewhere. Find it, correct it and the problem will be solved.
Read the ARCHIVES, within this forum, for other postings and replies on this topic.
The other resident small engine service and repair professionals and moderators, may offer alternate or additional suggestions, advice & opinions. Check back several times for additional replies.
Regards and Good Luck, Small Engine Forum Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
GA
04-09-02, 08:56 PM
This engine is bad about clogged jets in the bowl nut. Remove the bowl nut, and there should be 2 tiny holes in the un-threaded section of the nut. Push a piece of wire through them and make sure they are cleaned out. This will probably solve the problem. Let us know!
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
04-10-02, 01:35 PM
chewychops
Hi guys thanks for the help but wire in all the holes ports and
jets ? needle an seat and float are fine also this has going nuts
04-10-02, 01:53 PM
chewychops
Hi guys thanks for help. But i did put wire in all the holes jets
ports and needle and seat and float are fine. This has me
stumped ?
thanks chewy
Moderator Note 2 Chewy
I have merged your 2 questions into one.
Kindly do not post a new question on this same topic. If you have additional questions, Please use the REPLY button for that purpose. Doing so will automatically move the topic back up to the top of the list.
Using the REPLY button also allows other readers in the forum reading your topic and us moderators to easily follow along.
Your consideration on the matter would be appreciated.
Thanks,
Forum Moderator
Tom_B
stumped ?
thanks chewy
Thanks,
Forum Moderator
Tom_B
GA
04-10-02, 10:04 PM
Is the bowl filling with gas? Either the bowl is not filling due to a stuck needle or float, or line restriction...or...There is a stopped up jet or port in the carb somewhere. Inside the tube that the bowl nut screws into there is a smaller tube. You should be able to run a wire into it and see it come out inside the carb throat. If you have to, take the carb off and start over again...It's a simple carb, and there are only a few places that can cause problems.
God bless!
