Carburetor Question
Old 04-14-02, 05:05 PM
jfcm
Question Briggs & Straton 8HP engine
I replaced the carborator on my Father in laws riding mower. It starts just fine but when I throttle down it dies. I am at a loss, at first I thought it could be old gas but I drained that and replaced it with fresh. I also changed the plug on it. Could someone give me some other ideas to try it would be helpful.
Old 04-14-02, 05:57 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Several Possibilities
Hello and Welcome jfcm to our Do-It-Yourself Web Site and our Small Engine forum.
You haven't posted sufficient information on the engine and or equipment for me or any of the other small engine professionals posting help and advice within this forum to work with.
Kindly post the engine model, year & serial numbers. These numbers identify the specific engine model and the parts used to build it. It also helps to determine possible problem causes.
Doing so would greatly improve our chances of offering you specific corrective advice, helpful suggestions, technical problem diagnosis assistance, professional repair methods, proceduers and technics, possible parts causing the problem your describing.
In order to add more detail to this topic, click the reply button and it will allow you to add more detail. When a reply comes back but you still have a question on this same question, use the reply button once again.
Lawn mower shops and or small engine repair shops can also help determine what the possible problem may be. Bring the year, make, model and serial numbers and stop in at the store. Parts and repair manuals are also available at these stores. Locations can be found in the local phone book directory.
Regards & Thanks
Small Engine Forum Moderator
Tom_Bart......TCB4U2B2B.....Company Enterprises
Old 04-14-02, 07:43 PM
cheese's Avatar
Received 152 Upvotes on 139 Posts
A general diagnosis would be that the carb. needs adjustment. Maybe the Idle speed screw needs adjusting, or the air/fuel ratio may be too lean or rich. Post your engine information to allow us to make a specific diagnosis.
