Engine Starting Problem
lawnmoor will not start
i forgot to drain the gasoline from my lawnmoor last fall. now my lawnmoor will not start. do you have any suggestions on how to get the lawnmoor started?
Received 7 Upvotes
Hello and Welcome jet44 to our Do-It-Yourself Web Site and our Small Engine forum.
Cheese is very correct. The most likely problem is a gummed up carb and fuel system. The entire fuel system should be cleaned and flushed out and the carb too.
Kindly provide more detailed information about the engine. Knowing it's brand, age and type would help us determine what type of carb is on the engine.
Use the reply button to add the additional information.
Thanks,
Forum Host & Moderator,
Tom_B
Thanks,
Tom_B
