Engine Running Problem
josh1's Avatar
05-22-02, 09:34 PM   #1
josh1
3.5 hp briggs straton modifications
.. i have a "throttle free" new lawnmower that wont cut paper let alone grass.. the problem id say is this wacktackular throttle free design.. so a quick bend of the throttle lever and a piece of wire to the spring where it connects on the side and boom i can get this thng to rev like mad... is there any limit to over revving a mower engine and throwing a blade? i made sure the blade is tightened down with red loctite because wow without the air filter element its just nuts revving.. there seems to be a built in throttle stop on the linkage so that it only goes so far. Yes im nuts.. but am i too nuts for my own good? ---Josh
cheese's Avatar
GA
05-22-02, 10:16 PM   #2
Hi josh1!
The engine will blow in notime like that, not to mention the other possible dangers like breaking the whole crankshaft and throwing the blade like an F-16 into whatever it hits. The blade adapter could break apart too. The reccomended RPM is probably around 3,000 , depending on your model. Find your reccomended RPM, and set it using a tachometer.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
