Carb Settings
kahiki's Avatar
06-01-02, 04:09 PM   #1
kahiki
Tecumseh 8 hp Carb
I have a generator with a Tecumseh 8 hp. What would be a good begining setting for the carb jets? Thanks in advance.
cheese's Avatar
GA
06-02-02, 12:16 AM   #2
Are you changing the jets in the carb? Or are you adjusting the air-fuel mixture screw? The mixture screw should be turned in all the way until it lightly bottoms. Then back it out 1 1/2 to 2 full revolutions.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
kahiki's Avatar
06-02-02, 02:49 AM   #3
kahiki
I'm just cleaning the carb and adjusting it. Thanks for the reply. Great forum.
cheese's Avatar
GA
06-02-02, 09:53 PM   #4
If you run into any problems with it, let us know!
God bless!
pee-pa's Avatar
12-31-05, 09:33 AM   #5
pee-pa
need adjustments for carb.on hmsk-80
Posted By: cheese Are you changing the jets in the carb? Or are you adjusting the air-fuel mixture screw? The mixture screw should be turned in all the way until it lightly bottoms. Then back it out 1 1/2 to 2 full revolutions.
i am installing kit in carb.can,t rember adjustments this carb. is on a tec.hmsk-80 155545v[h] 6204 r on my snow blower.is it 11/2 turns on h or 2? thanks much
peepa
v8driver's Avatar
12-31-05, 02:33 PM   #6
1.5 turns out as a baseline...then fine tune when its warmed up
