carburetor leak
Old 06-05-02, 01:04 PM
gowitheflow
carburetor leak
I have a sears mower with a Tecumseh 4hp engine. Eng. mod# 143.434082. It was leaking gas from - it looked to me like- around the gas line at carb. fitting. Removed carb.; line was torn at fitting; replaced line. Engine wouln't start. Still leaking in fitting area. Took off carb;rmoved line. Tried to tighten plastic fitting at carb.It's not a screw-in fitting.It presses onto a metal insert which is pressed into carb. Bought new plastic fitting but comes with metal insert attached. Wrestled with old metal insert;got it out. Pressed in new metal insert with plastic elbow attached. Re-assembled; started engine; still leaking. Leak is between carb. and eng.; can't see back there even with mirror. I can see it dripping from gas line at area of plastic carb. fitting. Carb. is wet a little above where fitting is but can see no hole in body.
Where would the leak be if float was sticking? Thanks for ideas!
Gerald
Old 06-05-02, 08:34 PM
cheese's Avatar
If the float is sticking, it could leak from a number of places. One of the first would be the bowl vent. (on the side of the carb near the top). The needle valve seat on these is rubber and pushed up into the fuel inlet. They are prone to leak, and should be removed and replaced. Check your float to be sure it isn't full of fuel or sticking also.
