Painting my engine
Painting my engine
I have finished rebuilding my engine and wanted it to look good so i decided to paint it. Does any one know What type of paint to use and what can't be painted? Thanks
Ryan
Ryan
You can paint all of it, except the muffler. (you could paint it too, but it will burn off and stink). Use high-temp engine paint available at any auto parts store.
Received 7 Upvotes
Hello: Ryan
Painting can be best accomplished by applying grease over the parts that are not to be painted. Doing so saves time over masking the parts.
When the paint is applied, it will cover the grease also. Once the paint is fully dried, simply wipe off the greased areas.
This grease over parts method should be used on all manufacturers make and model plates and serial numbers. It can also be used on shafts, pulleys, wiring and most electrical parts and connections, etc.
