vapor lock?
lamaps's Avatar
06-10-02, 10:24 AM   #1
lamaps
vapor lock?
I have a new Murray model 205310x92 with a Briggs and Stratton Quantum 5.5 hp motor. When the motor gets hot the engine sputters and then quits as if running out of fuel. Whe engine cools it will restart. Can any one help????
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
06-10-02, 05:31 PM   #2
Hello and Welcome lamaps to our Do-It-Yourself Web Site and our Small Engine forum.
I would highly doubt the problem is caused by vapor lock.
I would more likely suspect a restricted vent cap.
If air cannot enter the fuel tankto displace the fuel leaving, fuel cannot flow out. That could be similar to vapor lock.
When the problem occurs, remove the fuel tanks cap and restart the engine. Do this immediately after the engine dies out.
If the engine restarts quickly and continues to run, the caps vent hole is restricted. Clearing the air opening or replacing the cap will resolve the problem.
The other resident small engine service and repair professionals may offer additional suggestions, advice & help. Check back several times for additional replies.
Read the other topic postings and replies offered on this topic of engines that fail to start and the ARCHIVES, within this forum, for additional help & information on this topic.
If you need further assistance, use the REPLY button to add any and all additional information, etc. By doing so, the additional information you add will remain within this posting. Using this method also moves the topic back up to the top of the list automatically.
Regards and Good Luck, Small Engine Forum Host & Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
lamaps's Avatar
06-11-02, 06:36 AM   #3
lamaps
eureka no vapor lock!!
There was a gas tank seal evidently put in upon shipment and the vent was definetly sealed. Thanks a million!
