clutch
Old 06-10-02, 04:38 PM
msmosey
clutch
Can I get a 1 inch clutch with a 1 inch bore?
Old 06-10-02, 05:45 PM
Sharp Advice's Avatar
Admin Emeritus
Question More Detailed Information Requested
Hello and Welcome msmosey to our Do-It-Yourself Web Site and our Small Engine forum.
You haven't posted sufficient information on the engine and or equipment for me or any of the other small engine professionals posting help and advice within this forum to work with.
On what type of power equipment? Kindly post the engine model, year & serial numbers. These numbers identify the specific engine model and the parts used to build it. It also helps to determine possible problem causes.
Doing so would greatly improve our chances of offering you specific corrective advice, helpful suggestions, technical problem diagnosis assistance, professional repair methods, proceduers and technics plus the possible parts causing the problem your describing.
Please use the REPLY button to add any and all additional information, etc. By doing so, the additional information you add will remain within this posting. Using this method also moves the topic back up to the top of the list automatically.
Regards and Good Luck, Small Engine Forum Host & Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
Old 06-12-02, 03:49 PM
msmosey
clutches
Engine Number-HS50-67147C-7171B
Tecumseh 5 hp engine.
I need to know if I can get a 1 inch centrifugal clutch with a bore that goes all the way through the clutch? I need the sprocket teeth to be inside next to the motor instead of being mounted at the end of the crankshaft.
Any feedback would be very helpful. Do they even make a 1 inch clutch that the bore goes all the way through?
Old 06-12-02, 06:20 PM
Briggs_Man
5 hp techumseh,, Yea they make Clutches that the Sproket sets in near the engine, But a 1 inch clutch, you have to be kidding a 1 inch clutch with a i inch bore. Ok where is the clutch if you need a 1 inch clutch w/ 1 inch bore,, Besides i have never seen a 5 hp tech or briggs with a 1 dia PTO end of the crank. most are 3/4 inch dia at the end. a 1 inch dia clutch would be outta the question since thats smaller than any weedeater uses,, Maybe im misunderstanding the 1 inch Clutch but the shaft is 3/4" Dia.
Trackbacks are On
Pingbacks are On
Refbacks are On
