Oil To Fuel Ratio
Old 06-12-02, 06:42 AM
Landlord Dave
Question Correct gas mixture
What is the proper mixture to achieve a 1:24 mix? I have a gas edger that is really picky and needs the exact mix. It is a two stroke engine. Does it matter what oil I use...2 stroke of course. Could I use an outboard two stroke engine oil?
Thanks in advance.
Dave
PS I usually mix two gallons at a time.
Old 06-12-02, 09:09 AM
J A Boggan
Dave,
In order to get a 24:1 mix, you need 10.7 ounces of 2 cycle oil per 2 gallons of gas. There are 128 ounces per gallon of gas.
Old 06-12-02, 09:26 PM
Sharp Advice's Avatar
Admin Emeritus
Hello: Dave
I would suggest to you to try a synthetic 2 cycle oil. Using this type of oil will not require measuring. One pack per gallon covers a wide range of mixtures.
There is also several other benefits to using a synthetic oil. Two of which are far less smoke and no carbon buildup.
A two cycle outboard motor is still a two cycle engine. Outboard engine two cycle oil is the same oil and can be used in lawn powered two cycle engines without any problems.
Regards and Good Luck, Small Engine Forum Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
